DIY car ramps
Old May 1, 2017 | 07:04 PM
Default DIY car ramps
I have been thinking of making some ramps to work under the car so I can add a new steering damper, change the oil in the diff and have a look around at the boots etc.
A quick search on the web gives a lot of ideas that have been put into practice.
These are some of the most interesting.
Old May 1, 2017 | 07:13 PM
Mrmiata's Avatar
Default Re: DIY car ramps
I prefer the second picture method.. properly planned out you can stay out of the sun!
Old May 1, 2017 | 07:17 PM
maggy55's Avatar
Hope that's not the gas tank he's welding on.
Old May 2, 2017 | 01:39 PM
blasco403's Avatar
Pretty funny...
I see this type of stuff when at my place in mexico very often, they get creative with whatever they have laying around...
Not sure if this was just posted so we could all have a laugh or if there was a question about building ramps... Anyway, I built ramps out of 2 x10's to do just the things you mentioned, I either drive onto them to raise the front or back onto to raise the back.
4 layers of 2 x 10 is what I built, 4 ft, 3ft, 2ft, 1ft stacked with a stop built on the 1ft piece. Good for the low splitter on the SRT6 as each rise is small. They also store easy as they fit together like tetris blocks...
Hope this helps some one.
Old May 2, 2017 | 03:35 PM
Originally Posted by blasco403
Pretty funny...
I am thinking of five levels, each level a little shorter than what you say. Using 2 planks of 2 x 10s like you say.
Old May 2, 2017 | 03:49 PM
blasco403's Avatar
Hey 180,
I forgot to mention that I also put some rubber on the bottom of each so they would not slide around when driving onto them on my smooth concrete floor in my garage..
Good luck..
Old May 3, 2017 | 10:55 PM
Hey 180,
Good luck..
I intend to use three 2 x10s x 10' cut into 5',4', 3', 2', and 1' lengths. The highest end will have each peice staggered by 1" to provide extra stability against tipping up and the other ends cut at 45 degrees or so.
Old May 4, 2017 | 01:34 AM
JSK's Avatar
JSK
Staggering the high end is a good idea. Might be kinda heavy.
Old May 4, 2017 | 01:40 AM
UrbanE's Avatar
DIY jack stands
2x4 with the rubber block to fit into the jack pad location.
Old May 4, 2017 | 08:34 AM
To reduce the weight I was thinking of 2 x 4s X 10" every 6" crosswise where the 2 X 10 step was. So that every other layer had 2 X 4s.
I did a layout on AutoCAD looks OK.
Old May 16, 2017 | 10:53 AM
Saw some 16,000 lb Rhino ramps on sale for $60 and purchased them. Seemed cheaper and easier and seem to have good clearance.
Old Jul 13, 2017 | 01:11 PM
mariontr's Avatar
How did those Rhino plastic ramps work out. I'm thinking about doing it..
Old Jul 14, 2017 | 09:43 AM
I've had a set of the Rhino Ramps for probably 6-7 years now. But mine are 8000 lbs capacity (Product 11903) and I don't think Rhino Ramps even produces this version anymore. Looks like they start out with 12000 lbs design & offer the 16,000 lbs version as the upgrade.
I've gotten considerable use from my set and hardly ever use the old metal ramps I have. Main difference - the angle of approach on the Rhino Ramps is shallow enough that today's cars can climb the ramp w/o rubbing. The Rhino Ramps are also much wider to accommodate today's low profile rubber. My old steel ramps had much steeper inclines (due to a higher overall lift) & I had to make a couple of transition pieces to enable the cars to go up the ramps. But the metal ramps have inclines that can be removed which is a plus for working in & around both front & back of tires. If I need that overall clearance, I get the steel ramps out. For changing oil by draining from the underside and/or replacing the steering stabilizer, the Rhino Ramps work great!
Old Jul 14, 2017 | 12:40 PM
mariontr's Avatar
Thanks this was the one I'm thinking about getting but saw some reviews about them breaking etc. and just want to be safe when I'm doing the oil change..
RhinoGear 11909ABMI RhinoGear 11909ABMI
Old Jul 16, 2017 | 09:19 AM
mariontr's Avatar
Also was thinking about these for jack stands rather than the scissors type is this ok for the jack pads?
Amazon Amazon
Old Jul 16, 2017 | 05:00 PM
Just about any pair of jack stands will do. You need to make sure the minimum height is something you can deal with when jacking up the XFire. You have to at least get that high. And make sure the jack stand top pad is large enough to accommodate a rubber-like spacer on it to prevent any scratching of the under carriage. (Note: I've never been a fan of the scissors-type jack stands.)
I also bought a pair of these (Jack Pad Adapters) which exactly fit into the jacking lift pads on the XFire. One of the issues you'll run into is that the ground clearance under the rocker panel of the XFire isn't all that much and adding these adapters, jacking pads, etc., can keep you from getting a lifting jack under the car.
Old Jul 17, 2017 | 09:43 AM
mariontr's Avatar
Thanks dedwards0323 for the response. I was also thinking about these Esco 10499 or Torin Jack Aluminum Jack Stand is a 3 Ton pair of adjustable jack stands
Last edited by mariontr; Jul 18, 2017 at 10:49 AM. Reason: trying to get rid of embedded media
