Old Jul 15, 2017 | 09:56 PM
  #303 (permalink)
pizzaguy
Default Re: Crankshaft Position Sensor
You can always see if there is 12 volts on the injectors' A+ side (same goes for the coil packs).
Now, seeing if the ECM is triggering them is harder, an oscilloscope would be needed as no meter will give you accurate indication of such quick pulses.
