Old Jul 17, 2017 | 08:40 AM
Speedy4x4's Avatar
Speedy4x4
Default Re: Connecting a powered sub
Originally Posted by T. K. D.
Hello all. I have an older Infinity basslink powered sub I'm looking to connect soon. What's the best locaction/path from cabin to engine compartment to run the power wire? Also if I tap into the rear speakers for line level sound, how is such done with the dual voice coil, considering it has 4 connection points? Any input appreciated.
Best way to run power wire, is on passenger side remove kick panel and pull carpet back and you will be at the stock infinity amp, then go under hood, take the battery out and you will see a rubber grommet you can put wire through and runs right into area where amp is at, a easy run, and if needed wire can by put behind kick panel and run under the silver plate, if you decide to pigtail off the amp while you are at it, do not run signal line and power in same location, you will get signal noise.
The powered sub is a small slim box made for under a seat?
Will it fit behind passenger seat?
