Old Jul 19, 2017 | 11:31 AM
Billto's Avatar
Billto
Default Re: Need Help - P0410 Code Again
Originally Posted by Gregm
tks alaxfire, My suggestion for anyone with a P0410 code to VERY carefully have a look at the solder connections on the RCM board. As others with more experience than me have said, the P0410 code is most likely a result of a burnt relay associated with the Secondary Air Pump and/or the solder connections on the RCM board. If I had looked more carefully when I replaced the relay and then the Secondary Aire Pump I would have saved a lot of time, effort and money.
Send the RCM to Tighed1. I had one done by him and kept it in the trunk. When I got the dreaded p410 swapped it out. Problem solved. Sent the defective one back to DJ and had that one done. (now in the trunk)
Bill T.
