Thread: High rpm idle
Old Jul 27, 2017 | 12:03 PM
Kingdav1954's Avatar
Kingdav1954
Default Re: High rpm idle
Originally Posted by IamNIkoSuave
https://youtu.be/zN8IlBOcc-U
been having this issue for weeks. I'll start the car, let it warm up and then I'll shut off...I then tap the gas pedal and let go and it holds like I'm still on it. Any help would be great. Recent work done before this issue was replaced water pump belt tensioner and idler pulley and also egr valve along with the rcm resolder. I replaced the egr thinking it was that causing the issue. Then had the rcm resolder by DJ Tighe thinking it would solve the problem, but no. Please please please please any ideas?
Now I understand when you said shut off you did not mean turn the engine off you meant let up off the accelerator pedal 👍 I got your meaning now
