Thread: High rpm idle
Old Jul 27, 2017 | 12:30 PM
IamNIkoSuave's Avatar
IamNIkoSuave
Default Re: High rpm idle
Originally Posted by Kingdav1954
Now I understand when you said shut off you did not mean turn the engine off you meant let up off the accelerator pedal 👍 I got your meaning now
Sorry, actually trying to describe this in written form is complicated. When I first crank it up, it'll idle fine. I can hit the gas pedal and it'll rev then drop back to normal idle. Now I shut the car off and turn it back on to make sure I dont get the high idle before actually start to drive...I hit the pedal the rpms hold at around 2k as if I'm still on the pedal but I'm not. If you watch the video, you'll see what I mean.
