Old Jul 28, 2017 | 09:10 AM
garjoe05's Avatar
garjoe05
Default Re: Key fob AND alarm not working
Two things to try.
If you press and hold either the lock or unlock button for about two seconds, look at the red window on the fob, you should see a round red light flash for about a second, each time you press and hold. If you see that light, it's possible your remote at least has power to work. If you don't see any light flash, then nothing is happening at all (no power). Is it possible you put the batteries in upside down ? They will fit upside down (and not work). See the + mark on the inside of the cover and the + on the batteries. Both + should face the same direction toward the removable cover. Also, CAREFULLY check the little flexible contact pins, maybe they are bent out of position slightly and not making contact with the batteries enough. Again, CAREFULLY is the caution word here, they probably will break off very easily if you bend too hard.
Next, on the programming of it, the way you typed it, it didn't exactly show the right procedure, but you may just not have described correctly what you were doing.
The instructions I got when I ordered a new fob said:
1. Insert the key into the ignition switch.
2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
You didn't mention you did Step 1 to insert it into the ignition switch first. I think that is an important part of the steps because the fob with authenticate with the car when it is in the ignition.
Eventually you will really want to have a second key any way, since a single key will somehow cause a crisis (can't find the one key, battery in fob dies etc.). Maybe you can budget to buy the second key and see the results with that. When I bought my Crossfire, it only had one key. I got mine through NeedsWings, which is the easiest and probably the most reasonable way to purchase a new key that you can find.
