Thread: High rpm idle
Old Jul 30, 2017 | 02:50 PM
ala_xfire
Default Re: High rpm idle
Originally Posted by UK Sid
I believe so.
All you can do is narrow it down.
AFAIK, the throttle position sensor sends a signal to the ecu. The ecu interprets this signal, in turn operating the throttle body. You've already replaced the throttle body, and mis-interpretation of the signal by the ecu is reasonably unlikely - leaving the tps?
The TPS IS the throttle body ! It is a resistive strip on a circuit board inside the black cover.
