Old Aug 1, 2017 | 04:50 PM
TheThomaswastaken's Avatar
TheThomaswastaken
Default Re: Need help - Crossfire won't start
I think that the method for jump-starting the charger is simply shorting the connection between ground and hot with a screwdriver. You can also purchase a push-botton shorting setup. At your own risk, obviously.
If you think that it is your starter is refusing to spin, the test is to smack it with a ball peen hammer while someone is turning the key.
