Need help - Crossfire won't start
Old Aug 18, 2017 | 08:04 PM
  #41 (permalink)
grip grip's Avatar
Default Re: Need help - Crossfire won't start
WOOOOHOOOO !!! Pop the Champagne !!!!
Congratulations !!!
Yeap, it's definitely a great feeling to have it up and running. My enjoyment was short lived on day one due to a bad heat exchanger pump. That was replaced today, so I took it out for some spirited runs to check the boost and IAT's. The air temps were incredible with the huge heat exchanger and working pump, but the power and boost aren't there. Max boost was just under 15 psi, so I've got either, belt slip, pulley slip, or a boost leak. I'll be digging in tonight once the engine cools off.
Old Aug 18, 2017 | 08:21 PM
  #42 (permalink)
Jeez, what does it take to make some people happy.
Finally running, now you got to monkey around with it till it quits again
Old May 31, 2020 | 10:08 PM
  #43 (permalink)
EliSax's Avatar
I have the same problem, can you help me or direct me in getting a new skreem. thank you
Old Jun 8, 2020 | 08:50 PM
  #44 (permalink)
Reliableron's Avatar
SOS diagnostics S.O.S. Diagnostics
Rob @ Needswings https://www.needswings.com/crossfire-skreem-repair
Either can fix a SKREEM problem!
