Old Aug 18, 2017 | 08:21 PM
  #42 (permalink)
ala_xfire
Default Re: Need help - Crossfire won't start
Yeap, it's definitely a great feeling to have it up and running. My enjoyment was short lived on day one due to a bad heat exchanger pump. That was replaced today, so I took it out for some spirited runs to check the boost and IAT's. The air temps were incredible with the huge heat exchanger and working pump, but the power and boost aren't there. Max boost was just under 15 psi, so I've got either, belt slip, pulley slip, or a boost leak. I'll be digging in tonight once the engine cools off.
Jeez, what does it take to make some people happy.
Finally running, now you got to monkey around with it till it quits again
