Old Aug 4, 2017 | 02:16 AM
UrbanE's Avatar
UrbanE
Default Re: Swap C32 into E32 (SRT supercharged into NA car)
I've just completed one
Mine was SRT (from several donors) into my NA Roadster
Automatic to automatic
My understanding is that you cannot install the manual trams into this setup
The drive shaft is different, the rear components are different as well. You have to flash the ECU to make it compatible. TCU would have to be from an SRT.
Suspension and brakes remain the same
Power steering hoses are different, same steering box, different trans lines at the rad to accommodate the SC cooler
You will also have to run power to the SC Waterpumpnand the secondary air pump
It's doable, it's a question of time and money. The money adds up in a hurry
