Old Aug 7, 2017 | 09:00 PM
grip grip's Avatar
grip grip
Default Re: Need help - Crossfire won't start
UPDATE:
I ran 12V though the wire that runs from Pin 1F and the starter and the car cranked over. I'm not sure why it didn't work last time, but it works now. I also tested and I'm getting voltage to the coils and CPS. I don't know the fuel pressure, but I did confirm the fuel pump is running by draining fuel fuel pressure from the shrader valve and seeing it return with a key cycle.
I really need a code reader that will read the deep hidden codes that Torque doesn't pull. If the Skreem was dead, would I be getting a code of some sort or light on the dash? What do you guys use to pull codes that don't trigger the CEL? I'd rather not mess with MG Star DAS if at all possible. It's going to be 3-4 weeks before I can get a trustworthy shop in Nashville to diagnose the car.
