Old Aug 10, 2017 | 03:16 PM
GraphiteGhost
Default Re: 74mm throttle body
Originally Posted by alexdc
So is this the plug and play 74mm throttle body?
01-06 MERCEDES V8 E500 S500 CL500 ML500 CLK500 S430 THROTTLE BODY ACTUATOR 61416 | eBay
Do I need to buy anything else for the swap. I looked at a few post but I'm confused.
Like George said below, make sure you get a new 'O' ring (don't reuse the old, its deformed). You can hold it in place with some petroleum jelly so it stays in place while assembling. IF after you run it a couple of cycles (so the car learns the new TB) it still hesitates/stumbles/runs rough, you just might have lost the groove /'O' ring alignment while assembly. It is usually where the vac leak is. That is why it is so very important to make sure it stays in place while assembling the TB to the intake. Good luck, you'll LOVE to peppier response.
Yep, that's the one, you will need a new O ring but that's all.
Right on George, a new 'O' ring is a MUST!
