Old Aug 11, 2017 | 09:40 AM
UrbanE's Avatar
UrbanE
Default Re: Swap C32 into E32 (SRT supercharged into NA car)
A straight swap with nothing else will not work
The secondary air pump and the SC Water cooler require requiring/ new circuit. You will also require an ECU flashed and reprogrammed to make it all speak together.
required are;
new trans lines (by the rad to accommodate the SC cooler.
New PS Hose. NA to SRT Are different.
The engine will fit but needs the SRT wiring or rework of the existing NA
I rewired much of my own items and had Rudy C to reprogram an SRT ECU
Straight swap with nothing else nogp. Lots of work for nothing.
Lots of items need to be changed, once reworked, yes this will work.
Just buy a cheap one as a donor
