James1549
Maybe something was spilled in the shifter? Too much soap or cleaner used?
That that was my first thought also, if it is , not All Is Lost 😉 take the console apart around the shifter and inspect the shift controller and wiring harness for moisture if you see any dry it off the best you can with a rag and then take a hair dryer to it and dry it out. I think someone else had this issue and this was the solution. Maybe some of the other members have a little more input on this.
