Old Sep 2, 2017 | 10:30 AM
onehundred80
Default Re: Fixed SC pulley ?
Originally Posted by No2fast
Hi,
good advise. Normally no boost on vacuum (part throttle/idle - closed throttle body). Seems that the electronic throttle pedal doesn`t get the correct information from the ecu and is still open. dangerous. With an old school throttle body (just controlled by wire) it would work for sure.
Steven
Berlin Germany
Woody should say if his SC on all the time after initial clutch engagement is true or retract the statement if he found later that it was not true. I have not seen any retraction to date and assume his initial statement is correct.
Calling Woody, are you receiving, over.
