Old Sep 2, 2017 | 10:43 AM
onehundred80
Default Re: IBF Pulley (Poland Pulley) Feedback
Originally Posted by JEFASOLD
If you go with the smaller SC pulley, you don't have increased speed of the pulley and ancillary stuff, water pump, idler, alternator, with a larger crank pulley you do have increased speed of belt, idler, water pump, etc. The best solution is stacked setup, SC 70mm, crank 181mm but you need larger capacity fuel pump, plus fuel pressure regulator and possibly larger injectors. I have the above setup, plus colder plugs, manis, DCAI, cooling mods, custom exhaust and Inmotion tune.
Increased belt speed with the same load on the pulley bearings will lead to earlier bearing failure, that is simple mechanics.
