UK Sid
Guys,
This just happened today out of the blue.
I have an '04 coupe and neither of my remotes will lock/unlock doors (batteries seem good).I have to lock the passenger side from inside the car manually and then use key to lock drivers side from outside and cannot lock the trunk. Also, the auto lock works ok when you drive off, and when I open the drivers door, the passenger one unlocks as it should. The interior switch works fine, locking and unlocking everything. The indicators flash as normal when using the remotes, so it appears they are communicating with the car.
Any ideas?
Have you tried resynchronizing the keys to the car, sometimes continuos pressure on a button screws up the lock/unlock programming.
Worth a try I'd say.
