Re: Car won't lock / unlock
UK Sid
I can live with the issue in the meantime. Only thing I can't lock is the trunk, but where I live is pretty quiet and I work at a high security site where the car park is monitored 24/7.
My siren started going crazy 2 years ago, I removed fuse 9
and have been driving it like that ever since, can't lock trunk you
say? Temporary fix: Grab some duck tape or whatever
strong tape you have and tape the little open/closed
door switch "door ajar" on the drivers side, It might take a few strips
of tape to hold it down .. Now when you exit the car the trunk
and passenger door will not automatically unlock and will
stay locked until you manually open them with button
on the center console, the driver door continue to use key to lock it.
Good luck
PS: You say the alarm has never worked since you got the car?
that's strange! usually they either go bad and never shut up like mine did!
or else they continue to work just fine ... I would def look at the alarm siren
first, take it off and leave it off .. put fuse 9 back in and see if it blows..
