Old Sep 13, 2017 | 11:42 AM
JEFASOLD's Avatar
JEFASOLD
Default Re: Front rims on back?
Originally Posted by Travish
Had a flat last night and tire is shot. I have a original set of front rims/tires in garage and was wondering if front rims can fit on rear temporarily till my new tires get here? Looks like I need to make a set of the adjustable arms to. The inside of the rear tires are definitely more worn.
thanks
I can't answer that but if you buy from TireRack they will be there in a day or two. Remove a wheel, put on one of the spare fronts. If it doesn't rub, put on the other and you're good. You can get the parts for the adjustable camber arm as listed in a thread here from Speedway Automotive. They work great!
