onehundred80
There is damage only at the filter end of the CAI, the damage is to the filter clamping collar, it has fell off and been sucked through the CAI and became jammed under the butterfly of the TB.
O, OK, in that case probably just vibration at the filter end was the cause.
Might have a peek at mine and see if I can add a brace at the end of the filter somehow.
Maybe 2 washers, one inside and one outside with a threaded compression type insert and a strap to the center support brace.
Or, even easier, a brace from the center support under the filter with a big hose clamp.
