Old Sep 27, 2017 | 10:40 AM
NeedsWings's Avatar
NeedsWings
Default Re: intake manifolds
Originally Posted by dinasrt
Rob, One of the images shows a relocated AIT sensor bung onto the manifold. I have considered and have wanted to do this, and even have a spare SC y-pipe to steal one out of. My question is, Will the temperature at that new location be the same, higher, or lower than the stock location(after bringing up to operating temp.). Has anyone tested the temperature at the 2 different locations with an infra red thermometer?
that was done so we could spray water/meth into each intake plenum inlet tube and have the sensor read the newly cooler air. yes without spraying the water/meth the sensor would read slightly warmer as it is further upstream away from the intercooler but it is very minimal difference. I wouldn't recommend the trouble of moving it if your not plan on spraying.
