Old Sep 27, 2017 | 08:36 PM
dinasrt's Avatar
dinasrt
Default Re: intake manifolds
that was done so we could spray water/meth into each intake plenum inlet tube and have the sensor read the newly cooler air. yes without spraying the water/meth the sensor would read slightly warmer as it is further upstream away from the intercooler but it is very minimal difference. I wouldn't recommend the trouble of moving it if your not plan on spraying.
Thanks for the explanation. Yes, this is the very reason I wanted to do this(spraying/cooling). I have a bung at each intake plenum tube as you may remember. I want to spray in both those locations, as well as pre SC at a bung on the silicone y-pipe intake. Total of three spray nozzles. The plan is to re-locate the boost sensor to the lower y-pipe.
