Thread: BAS/ESP light
Old Oct 2, 2017 | 11:22 AM
Kingdav1954's Avatar
Kingdav1954
Default Re: BAS/ESP light
Originally Posted by DHS
So I have unplugged and plugged up all the connector on the master cylinder with them looking clean and tight. So next step?
Tnx
Dab
You have not been forgotten, I'm researching the matter now, I will post if I come up with something 👍 in the Mean Time try this, disconnect the negative battery cable and then turn on the headlight switch for 10 to 15 minutes then reconnect making sure all connections are clean make sure you turn off the headlights switch first 😀 don't want any fireworks there by the battery would not be a good thing. Sometimes the simple things work. Have you check for trouble codes?
AutoZone or O'Reilly's , Advance Auto any of them will check For trouble codes at no charge.
