Old Oct 9, 2017 | 12:54 AM
dinasrt's Avatar
dinasrt
Default Re: supercharger light
Originally Posted by bucksarrow
when the switch is on the pink and black is hot. When the supercharger is energized the ground is made [ the led is polarity sensitive] so you should be able to find a hot wire close to the dash or just run 2 wires one hot one ground.
I'm sorry, but am confused. If you tap into the BK/Pk which becomes hot, wouldn't you then connect the other wire from your light to a ground, and not a "hot wire close to the dash" as you suggest?
