Old Oct 15, 2017 | 01:48 PM
Intimacy's Avatar
Intimacy
Default Re: Roadster trunk stuck closed.
It sounds to me like your top did not finish the cycle the last time you put it up, so you have an error when you try to put it down AND the electric lock has not unlocked because, again, the cycle is not finished - the TCM thinks you are not done putting the top up, so it has not commanded the electric lock to let go.
Read this thread, POst 73 in particular. Once you get the trunk open, do the lock mod described so you never to thru this again. You can disable the ELECTRIC lock, the pneumatic lock will still work - the electric lock is only for the 30 seconds the top is moving up or down, you don't need it.
https://www.crossfireforum.org/forum...-jammed-4.html
The top finished cycling up; it errors when commanded down because the partition in the trunk is not properly aligned. Both sides of the leading edge have to be positioned on the hooks that hold it in place, and there are sensors there to ensure correct placement.
However, the bag in the trunk pushed the partition out of place when the trunk was slammed... which wouldn't be a problem, except that the trunk is stuck.
