Thread: Rcm
Old Oct 15, 2017 | 08:26 PM
onehundred80
Default Re: Rcm
Originally Posted by Firemanken
Replaced crank case sensor as advised! That did the trick.
Car is running good, BUT now the check engine light is on.
Bought a Autel A319-OBDll code reader to check engine light code. Plug on reader doesn't connect with car OBD plug.
Is there an adopter to buy to make the connection?
Thanks again For any help.
You are trying to connect it with the plug properly aligned and you have opened the cover of the cars OBD port?
