Re: BAS/ESP light
Well this mourning I replaced all four ABS sensors, rears are very easy the front plug mates with the brake pad sensor so at first it looked like I got the wrong cables. They clip together to plug in. Well I did the wheel turning procedure twice and the light is still on!
So what next, the yaw sensor? Where is it located in the car?
Dan
Did you do a resistance check for all for sensors? Voltage supply check from the controller module? Did you get the actual codes for the light? Unless you do this could get pricy just throwing parts at it. There are too many reasons for this light like 180 said.
