ala_xfire,
I can't locate a TB o-ring locally so I'm going to just clean the TPS connector at the TB. Can you give me some tips on removing that? Spent 15 minutes on it without luck.
Also read threads on vacuum leaks. I can't hear anything obvious. Can you suggest some locations that are more typical?
Thanks.
PS This guy had what sounds like the same problem but didn't post a resolution:
https://www.crossfireforum.org/forum...ssue-help.html
