stevieb
I believe mine to be similar Dave but to be honest haven't checked the exact numbers.
All I can say that doubled up to the new paddle shift makes for a much more pleasing driver experience.
Stevieb,Yes, i Want those paddles shifters too , they must be alot of fun but the install scares me abit . plus im broke atm :-(
Dashcommand (or TorquePro) work well and IF you input all the cars parameters
Correctly it is quite accurate too.
On mine Dashcommand is within 5% accurate on actual fuel consumption , its 5% optimistic.
A tweak to the Brake specific and or the volumetric efficiency settings and it would probably be spot on . I havnt done that but i should.
in Dashcommand /vehicle/advanced settings i have the BSFC set at .55lb /(hp*h)
and Volumetric efficiency set at 70%
changing these two would likely alter the HP report .
I think the 378hp report i got, allthough it was on a dead flat road , a little optimistic .
I would expect about 350+ hp with the mods i have .
