xodus52
I pulled the tensioner pulley off of the assembly to swap out the bearing. Seems that the pulley assembly is molded around the bearing, so I can't see how it could be done without damaging the pulley (unless I'm dense and missing an obvious solution).
So now I'm looking to buy a replacement pulley but can't find any without buying a whole new assembly. Does anyone know a part # for it or a place I could purchase one? Checked RockAuto and the usual suspects with no luck.
You can replace the pulley by itself, it is the same pulley as the idler pulley according to one post I found. Pulleys are available at auto parts suppliers. There is nothing special about these pulleys.
