Old Nov 16, 2017 | 01:29 PM
onehundred80
Default Re: Oil change extractor
Originally Posted by PNA
I've used one for years. I love it. It holds almost 2 full oil changes from an XFire. Was about $100. Hand pump, takes between 5-10 minutes. Very quick if the oil is hot. Also, very easy to then just take the recepticle to an autostore and dump the oil for recycling. Clean, not need for jacking the car, removing the cover under the car or messing with an oil pan. To me, it's the only way I will change the oil in this car.
OK!. One thing missing though what model are you talking about? Almost doing two changes is not much benefit really.
My one does one change and a bit more (ten liters) and as it does not pump out that is heavy enough to tip. Suck it out when it is warm, not hot as that will warp the plastic.
