Old Nov 17, 2017 | 07:00 AM
PNA's Avatar
PNA
Default Re: Oil change extractor
OK!. One thing missing though what model are you talking about? Almost doing two changes is not much benefit really.
My one does one change and a bit more (ten liters) and as it does not pump out that is heavy enough to tip. Suck it out when it is warm, not hot as that will warp the plastic.
I'll see if I can find the model and post later.
Almost 2 oil changes is just to provide a litmus on volume. I use it for other cars / equipment as well so it's helpful to have a larger capacity in my case. I only need it for 1 oil change a year for the crossfire because I only put about 3 to 4 k miles a year on mine. I can go full hot on my oil because my extractor has a metal flex tube so no worries on warping plastic tubing and my container is very heavy / thick plastic so it's not a concern either. It's pretty tall and on a good platform so tipping isn't an issue and even if it did it's a contained unit so no spillage from it either.
Here it is: Yamaha HT Moto Fluid 15 Liter Oil Extractor ATV PWC UTV SBT-15LEX-TR-10
https://www.ebay.com/i/390606161875?chn=ps&dispctrl=1
Last edited by PNA; Nov 17, 2017 at 07:12 AM. Reason: Updating for additional information
