Old Nov 21, 2017 | 10:44 AM
onehundred80
Default Re: Crossfire will not start!
Originally Posted by Bulldog
I did check the RCM and with the key on the engine control relay activated but the fuel pump relay did not. I manually activated it but still no fuel at the rail. I even tried the re-solder fix of the three contacts on the RCM. All fuses are good and there is power to and through all fuses. What do yo mean by an open coil?
Disconnected the crankshaft and camshaft sensors and sprayed contact cleaner (they looked immacualate).
I will have access to a code reader in the next day or two and will check for codes.
There seem to be too many coincidences here, relay does not work and the fuel pump is not delivering fuel when the relay is manually closed.
Too many for my liking.
Is there any power at the relay contacts?
