Old Nov 24, 2017 | 10:20 AM
KDW4Him's Avatar
KDW4Him
Default Re: Crossfire will not start!
NOTE: If the engine relay energizes, and the fuel relay does not, then you have an open coil on the fuel relay or fuse 3 is blown :
Right but have you ever manually pushed the relay just for a test? Same with the air pump relay, ever manually push the contacts to see if the air pump works?
