Old Nov 25, 2017 | 04:39 PM
onehundred80
Default Re: Car Alarm Going Off!!!
Originally Posted by Jim Holian
chxf - I'm having the same problem as others above. As you suggested, until I can get in to the dealer, I pulled the fuse. I now have to manually lock the car with the key. No big deal! I would prefer to use my key fob remote but the absence of the fuse, I guess, prevents that. I'm a zero when it comes to electrics and computers. Seems like there should be a way to unhook (electrically) the alarm. Anybody have any ideas? I can't even FIND the alarm so, I need help there too.
Thanks, Jim
The siren is under the cowl in front of the windshield, take off the cowl and you will see it to unplug?If you can take off the cowl you might as well remove the alarm and replace it with a new alarm while you are at it. It is plug and play.
