Re: No start/anti theft issue
First thing I would check is if the fuel pump is running and you have pressure at the test port.
If you have fuel pressure, then
pull a wire off one of the spark plugs and hook it to a plug held against the valve cover to see if you have ignition.
If not, I would replace the Crankshaft Position Sensor.
Could also be a problem with soldering or a relay in the RCM.
So many choices ! How to decide ???????
