Old Dec 11, 2017 | 10:55 PM
Cowboyzion's Avatar
Cowboyzion
Default Re: No start, no crank...no ideas!
Originally Posted by Padgett
Does the tach wiggle ? First thought for "cranks but does not run" is a fuel pump that died (can check the rail pressure, should have at least 40 psi when you turn the key on (or can pull the cover, pour a 1/2 oz of gas in the intake, put the cover back on and see if fires even briefly. If not the next suspect is the CPS.
i sprayed starting fluid in it and it ran for a momment.
