Old Dec 12, 2017 | 09:14 AM
  #42 (permalink)
onehundred80
Default Re: Fitting a double DIN radio
Originally Posted by UrbanE
Cut out the existing faceplates (that have the lighter and seat belt light). This will sound dumb but you cut them out to reuse the holes for the lighter and seat belt light.
Once you’ve cut up the existing faceplates, tape the cutout squares over the desired location on shifter plate, mark them and cut the square hole that you’ll mount the Lighter and seatbelt light into.
JB weld them into place, body filler, sanding and filler primer.
Easy
Since my post I have had it suggested that the lighter should go into the passenger side wall of the centre console and Padgetts idea of a airbag light might be better and cheaper than taking a bulb from a Crossfire ash tray unit.
All my original parts will be put in a box and stored. I do this to all parts that I replace, whoever gets the car next has the option of retuning it to all stock equipment, that includes an OEM nav head unit.
