Hangman
OP, I am having the exact same problem. Went to start the car one morning and it would just turn over and over but would not start. After a few attempts, it would start. Later, it would just turn over and over again and not start. I got it to start once and it ran for about 20 seconds then dies. Then it would just turn over and over again but would not start.
One thing I do notice, is that normally, as you turn the key to on before starting the car, you would hear a sound (I assume a fuel pump) sound. But in the times it would not start, I do not hear this sound. Everytime I try to start, if I hear the pump sound before starting, then the car would start, otherwise it will n ot start and the engine just turns over and over again.
Its a 2007 limited roadster and only has 25k miles on it.
Does this sound like the RCM board issue that is discussed here?
possible the fuel relay in rcm is going bad. That was the issue with mine.
