Steve Jr
Did you check for vacuum leaks as suggested? Also pull the MAF sensor an clean it , inspect air filters (change). Charge the battery fully, before you go out. Make sure you clean an inspect the battery connections as well as the cables. Also the grounding lug that attaches at the fender.
SRT-6 does not have a MAF.
