syfi
Looks like you'll want to look at the higher priced models to get the bennies of the pro scanners. Here's a very popular scanner that is guaranteed to read and clear all codes including ABS and Transmission codes, plus is internet up-gradable and can print out results via PC.
Launch Tech Code Reading Scan Tool CRP123 - 301050116
Complete Domestic, Asian & European Coverage for ABS, SRS, Transmission & Engine
Enhanced Data Stream for ABS, SRS, Transmission and Engine
Auto Vehicle ID, Auto Module Search & Ultra-fast Protocol ID
Reads & clears codes on Engine, Transmission (A/T), ABS, and Airbag (SRS) systems – on all makes and all models
Includes all functions of previous CReader models for OBD Generic
Support for all 10 test modes of OBDII with Enhanced OBDII Mode 6
Retrieves generic and manufacturer specific codes – both permanent & pending
Turn off Malfunction Indicator Lamp (MIL)
View freeze frame data and I/M Readiness monitor status
Graph, record, and replay data in full color
Enhanced Help Functions
Intuitive Interface and Button Operation with Sleek, Rugged Design
3.5” TFT color display
Multilingual menu with DTC definitions in English, Spanish & French
Internet updateable
Print Data Via PC
Amazon.com: Launch Tech 301050116 'CRP123' ABS, SRS, Transmission and Engine Code Scanner: Automotive
I bought this one originally but had to return it because you can't use it with a Apple computer.
Bill T.
