Thread: '05 crossfire
Old Dec 18, 2017 | 03:49 PM
ala_xfire
Default Re: '05 crossfire
Originally Posted by wgc
Thanks I was thinking same thing. But what could obstruct the oil Gary
If you haven't changed the oil and the filter on the recommended basis, or used non synthetic oil, then there could be some sludge buildup.
I faced this same issue in my old '89 Probe in which I hadn't used synthetics.
I had to pull the rocker arms and use a set of carb jet drills to clean out the oil passages in the rockers.
( this engine is quite similar to the crossfire engine in that it is overhead cam with 3 valves per cylinder )
That fixed it's clicking.
