Thread: Oil Change
Old Dec 21, 2017 | 03:45 PM
onehundred80
Default Re: Oil Change
Originally Posted by Steve Jr
No, none of these cars have a plug that is not removable. People have heard horror stories about a plug not being installed correctly. An it BLOWS UP! Who ever did the last oil change , overtightened the plug. But ,I've got to ask , is there a hex head plug in it? If yes ,then moving on. The most important thing is , after removing it is replacing the copper crushable washer on it. When tightening back up ,its only 22 ft. lbs. Which isn't a lot. Use the search feature an put in ,"drain plug question" with the quotation marks, this thread should alleviate some of your concerns.
I am not sure what you are saying, but I think you are recomending leaving it jammed in and use a topsider - correct?
