Re: Oil Change
"I am unsure how to get all of the oil out of this pan unless the pan is perfectly level" - like was said, my driveway slopes so on the ramps the car is level.
BTW you can understand oil starvation on a hard turn doing damage if low. What people do not understand is too much oil will have the crank throws whipping the surface and aerating the oil (air bubbles in oil is not good for bearings) and throwing oil against the bottom of the oil control rings. Oil in the combustion chamber can damage catalytic converters and O2 sensors.
Make more sense ?
