Old Dec 23, 2017 | 07:45 PM
RED DOG's Avatar
RED DOG
Default Re: Now I need some advice / help! AC system / heater control valve assembly
OK guys . . . Thanks for the additional information. I went to one of my working cars and pulled fuse #15. That DID cut the power to the heater control valve connector so that circuit is where my problem lies. I'll investigate it further tomorrow.
Do you actually have power at pin #2(?) on the valve connector? If you do and you should as it comes straight from the fuse then it is a grounding problem somewhere.
That is what I see with my very limited knowledge of sparky stuff. A meter between a good earth and pin #2 (?) should give a reading of 12 volts.
I'll check that tomorrow Dave. I understand . . .
Also, I took my original climate control head and just did the mod / fix shown on the link that Dave provided . .
CLICK
I'll swap that head back in tomorrow and see if there is any change. Will keep you advised. THANKS for your assistance.
Bob Davis (Red Dog)
