Old Dec 24, 2017 | 12:56 PM
ala_xfire
Default Re: Now I need some advice / help! AC system / heater control valve assembly
The REST pump on mine ( an NA ) is down where the intercooler pump is on the SRT6, I don't know where they put it on the 6.
You test the REST pump by pressing the REST button with the ignition switch off.
There are NO inline fuses in these cars ( from the factory ).
Did you meter the fuse ? Did you check the fuse cavity for 12v ?
