Old Dec 27, 2017 | 02:45 PM
ala_xfire
Default Re: Alternative Methods to Acquired Power Control Module?
Originally Posted by 25jewel
Hi ala_xfire,
Thank you for your response. Most importantly, I truly appreciate the vast resources from this wonderful forum.You are correct, it is the SKREEM from the service manual, which I followed to remove the module. However, when pull up the part #170-820-18-26 printed on the module (it has a Siemen part # as well) it listed as Power Control Module, and the scanners listed it as such as well. That's why I went with that.
O, OK. I was confusing PCM as mentioned with the PTCM module located by the battery.
