25jewel
Hi ala_xfire,
Thank you for your response. Most importantly, I truly appreciate the vast resources from this wonderful forum.You are correct, it is the SKREEM from the service manual, which I followed to remove the module. However, when pull up the part #170-820-18-26 printed on the module (it has a Siemen part # as well) it listed as Power Control Module, and the scanners listed it as such as well. That's why I went with that.
Please disregard my last about scanner code. The code is P2071 Security Key.... not sending signal. Which is the SKREEM. However, the part # on the SKREEM when pull up is listed as Power Control Module. So confusing....
